Lookout
Lookout 4.0
I have two questions regarding Lookout 4.0.
They are:
How can I make the developer version login without user intervention,
i.e. how can you get the "nobody" account to be logged in automatically,
as you could do in Version 3.8
How do I know the current I/O usage, i.e. how do I know what is the
total count of inputs and outputs that a system is configured to use. In
Version 3.8 you could see this in the About section of Help
Regards
David Crofts
[See first answer for additional information]
(4,998 Views)
[Attachment(s) for question]
(4,998 Views)
1> Remove the password of your
"Administrator" account i.e., leave the password field blank. This will
log you on automatically.
2> The I/O points count information will be available in the next release
of Lookout 4 under the Help>About Lookout box.
Khalid Ansari
National Instruments.
support wrote:
>This is a multi-part message in MIME format.>--------------
>>I have two questions regarding Lookout 4.0. They are: How can I make the
developer version login without user intervention, i.e. how can you get the
"nobody" account to be logged in automatically, as you could do in Version
3.8
How do I know the current I/O usage, i.e. how do I know what is the>total
count of inputs and outputs that a system is configured to use. In>Version
>>Regards
>David Crofts>--------------
(4,998 Views)
Good info . thanks
Message 4 of 3
(2,257 Views)
