Lookout
Lookout 4.01. and the Internet
I 'd like to create a html page out of my process and acces it through the
Internet Explorer.
Everything works fine except, ther is an error at the end of the downloading
process (for the Loookout controls): Error downloading file!
Any idea??
Rajko
(4,146 Views)
Hello Rajko!
First I have some questions to you.: How come your e-mail address ends with
@ni.com? Do you work at National Instrument? If so, why are you asking these
questions?
I have the same problem as you, only this is in 4.0. I think that maybe it
has to do with the web server setup.
In 4.01 lookout will not create the page and gives the following message:
"Web Export Error"
"This process will not run in a Client version of Lookout."
Regards
Johan
"Rajko Eichhorn" wrote:
>Hi,>>I 'd like to create a html page out of my process and acces it through
the>Internet Explorer.>>Everything works fine except, ther is an error at
the end of the downloading>process (for the Loookout controls): Error downloading
file!>>Any idea??>>Thanks>>Rajko>>
(4,146 Views)
Hello Johan,
The reason why you're getting the "Web Export Error..This process will not
run in a Client version of Lookout" error is because you're trying to export
a process which has driver object(s) in it.
Lookout Web Client is like the regular Client version of Lookout, that is,
without any driver objects (no Modbus, AB, Mitsubishi, etc., Objects). So,
when you try to export a process which has any of these driver objects, Lookout
4.0.1 intelligently warns you to not to do so.
The correct way of exporting a process to a web server, is to first create
a "client" process with considerations such as no driver objects, the panel
is activated/maximized, etc. and export this process rather than the server
process which has driver objects to communicate wit
h your hardware.
The most common problem users encounter with Lookout Web Client is the security
setting for Internet Explorer. Make sure you have a security of 'Low' for
your Internet, and the Local Intranet options in IE.
Khalid
"Johan Moflag" wrote:
>>Hello Rajko! First I have some questions to you.: How come your e-mail
address ends with>@ni.com? Do you work at National Instrument? If so, why
are you asking these questions?
has to do with the web server setup. In 4.01 lookout will not create the
page and gives the following message: "Web Export Error" "This process will
Regards
Johan
>>"Rajko Eichhorn" wrote:>>Hi,>>I 'd like to create
a html page out of my process and acces it through>the>Internet Explorer.>>Everything
works fine except, ther is an error at>the end of the downloading>process
(for the Lo
ookout controls): Error downloading>file!>>Any idea??>>Thanks>>Rajko>>
(4,146 Views)
Hello Khalid!
I discovered the driver object problem just before you came with the answer.
But thanks anyway.
After fixing this problem, I still can�t view the process from a another
computer over our intranet. I think i has to do with the Personal web server
setup.
Do you have any Idea on how I should set this up?
Do I need to have client licences registrated in Lookout for this to work?
Best Regards
Johan Moflag
"Khalid Ansari" wrote:
>>Hello Johan,>>The reason why you're getting the "Web Export Error..This
process will not>run in a Client version of Lookout" error is because you're
trying to export>a process which has driver object(s) in it. >>Lookout Web
Client is like the regular Client version of Lookout, that is,>without any
driver objects (no Modbus, AB, Mitsubishi, etc., Objects). So,>when you
try to export a process which has any of these driver objects, Lookout>4.0.1
intelligently warns you to not to do so. >>The correct way of exporting
a process to a web server, is to first create>a "client" process with considerations
such as no driver objects, the panel>is activated/maximized, etc. and export
this process rather than the server>process which has driver objects to communicate
with your hardware. >>The most common problem users encounter with Lookout
Web Client is the security>setting for Internet Explorer. Make sure you
have a security of 'Low' for>your Internet, and the Local Intranet options
in IE. >>Regards,>>Khalid> >>"Johan Moflag" wrote:>>>Hello
Rajko! First I have some questions to you.: How come your e-mail>address
ends with>@ni.com? Do you work at National Instrument? If so, why>are you
asking these questions? >>I have the same problem as you, only this is in
4.0. I think that maybe it>has to do with the web server setup. In 4.01 lookout
will not create the>page and gives the following message: "Web Export Error"
"This process will>not run in a Client version of Lookout.">>Regards>Johan>>>>"Rajko
Eichhorn" wrote:>>Hi,>>I 'd like to create>a html
page out of my process and acces it through>the>Internet Explorer.>>Everything>works
fine except, ther is an error at>the end of the downloading>process>(for
the Loookout controls): Error downloading>file!>>Any idea??>>Thanks>>Rajko>>
(4,146 Views)
Hi Johan,
Depending on what server you're using, the setup steps will differ. You'll
have to get some help from the Server company in setting it up correctly.
Once you're sure the server is setup correctly, make sure the security settings
(for bothe Internet and Intranet) in your Internet Explorer are at Minimum
and try again. If problem persists, try this on the same machine as the
Server first.
Khalid
Hello Khalid!
But thanks anyway.
setup. Do you have any Idea on how I should set this up? Do I need to have
Best Regards
Johan Moflag
>>>"Khalid Ansari" wrote:>>>Hello Johan,>>The reason
why you're getting the "Web Export Error..This>process will not>run in a
Client version of Lookout" error is because you're>trying to export>a process
which has driver object(s) in it. >>Lookout Web>Client is like the regular
Client version of Lookout, that is,>without any>driver objects (no Modbus,
AB, Mitsubishi, etc., Objects). So,>when you>try to export a process which
has any of these driver objects, Lookout>4.0.1>intelligently warns you to
not to do so. >>The correct way of exporting>a process to a web server,
is to first create>a "client" process with considerations>such as no driver
objects, the panel>is activated/maximized, etc. and export>this process rather
than the server>process which has driver objects to communicate>with your
hardware. >>The most common problem users encounter with Lookout>Web Client
is the security>setting for Internet Explorer. Make sure you>have a security
of 'Low' for>your Internet, and the Local Intranet options>in IE. >>Regards,>>Khalid>
>>"Johan Moflag" wrote:>>>Hello>Rajko! First I have some
questions to you.: How come your e-mail>address>ends with>@ni.com? Do you
work at National Instrument? If so, why>are you>asking these questions?
>>I have the same problem as you, only this is in>4.0. I think that maybe
it>has to do with the web server setup. In 4.01 lookout>will not create the>page
and gives the following message: "Web Export Error">"This process will>not
run in a Client version of Lookout.">>Regards>Johan>>>>"Rajko>Eichhorn"
wrote:>>Hi,>>I 'd like to create>a html>page out of my process and acces
it through>the>Internet Explorer.>>Everything>works>fine except, ther is
an error at>the end of the downloading>process>(for>the Loookout controls):
(4,146 Views)
