Lookout
Lookout 4.5 Alarm Diaplay Options
The ability to have control of the header info for the alarm display (ie. header,tag,group...) that was in V3.8 no longer available in 4.5. We know N.I. is working on it but when can we expect it??? A similar question was posted on this site over a year ago when 4.0 was released.
(4,173 Views)
Search the on-line help for INI file settings. Some of the alarm panel headers can be changed by manually editing the lookout.ini file and restarting Lookout. Unfortunately, there is no way to make the changes from within Lookout.
(4,173 Views)
Tried what you suggested with no results.. Talked to tech support and they confirmed that the header can not be disabled. The sections(tag,group...)can be shortened but not removed from the window. The .ini files states that it is possible but could not reproduce.
(4,173 Views)
