Lookout
Lookout 4 fails
I have a question. I've installed Lookout 4.0 into Win 95 and the installation
goes fine. After installation computer will be restarted. Win 95 raises fine
and Lookout work nicely. After I shut down the machine and start it again
the Lookout fails to start. Service manager reports: Citadel service not
loaded and Time sync service not loaded. Has anyone had problems like this.
Tomi
(3,430 Views)
If the computer is not on the network you will need to create/edit a fine to indicate it is not on the network. If you do not have a LOGOS.INI in your Windows sub-directory (Windows for Windows 9x or WinNT for NT) create a new one and add the entries below:
[LogosSockets]
NoNetwork=1
Also recommend contacting NI for Lookout 4.0.1 build 61 or upgrading to Lookout 4.5.1 build 18.
(3,430 Views)
