Lookout
Lookout 6.0 Login Failure
I got called into a customer site using Lookout 6.0.  They came in this morning to a general login error. I cannot get into the program with any username or password combination.  i have de-activated, uninstalled, installed and re-activated and am having the same problem.  The only thing i can see is that it may have done an update over night and the only one i can see is XP SP3.  This computer runs a water treatment facility which is now down because they can't access the controller.  Any help would be appreciated.
(6,491 Views)
Accepted by topic author Dbregler
I don't know if this is related. but I have it from our Allen Bradley techie, that RSLinx doesn't like SP3. You talking to any Allen Bradley controllers using RSLinx? (I havn't had a problem using SLC-5/05 ethernet driver direct (no RSLinx))
(6,485 Views)
AB Strikes again!
(6,452 Views)
