Lookout
Lookout 6.02 hyper trend
I test the Lookout 6.02 hypertrend changes. On the client, the hypertrend values sometimes disappear, or have diferent values than on the same hypertrend on the server. The diferent values are when i see long time unchanged values, i don't know when disappear the values, but many times is happen. When i connect to the 6.01 server with same hyperternd, the values are good. On the 6.01 server the CPU utilization is very high, that's why i try the Lookout 6.02.
(4,015 Views)
Both server and client Lookout versions must be the same (6.02 in this case).  I have not seen this issue but I will try to verify if you can layout specifics a little more.
Hypertrend data will temporarily dissappear when refresh is in progress.  Lookout 6.02 takes significantly longer to do screen updates than previous versions for some reason.  Maybe NI can speak to this issue?  Previous versions did not freeze entire panels and/or lookout screens while updating a hypertrend, but 6.02 takes it's time and definitely blanks more panel/window during updates at the GUI.
Message Edited by erblock on 02-07-2006 12:26 PM
(3,991 Views)
We have been having the same issue.  The new hyper.cbx file seems make it work better.  But we have other issues now with objects because we installed the latest patch602 files.
(3,923 Views)
