Lookout
Lookout 6.1 Edit Mode Bug
I don't remember seeing this in older versions of Lookout, but in 6.1:
Edit mode allows you to open a second session of object editing.  It used to be you had to close an open object edit (connections, data member configuration, etc) before opening another.
Well in 6.1, it will let you open a second one....and Lookout will always crash after you close them and save the process (sometimes it will crash before you try to save).
Ed
(6,590 Views)
Do you see this bug in newly installed Lookout 6.1 without any updates or fix?
What's the OS?
Ryan Shi
(6,581 Views)
Ryan,
Windows XP SP2 32-bit, fully updated.  Dell Precision 690 with single Xenon 5160 dual core @ 3.0GHz
I sent you an email with more details....
I have not restored to original release 6.1 only.  I will progress the entire upgrade path scenario when I have time to reload the machine in question and I'll test each phase.
Ed
Message Edited by erblock on 03-31-2008 01:38 AM
(6,577 Views)
I think it's the OS issue.
The "Edit Connection" is a dialog. Lookout just tells Windows to create a popup dialog. For a dialog, Windows should let it be the only one that you can operate.
Ryan Shi
(6,562 Views)
