Lookout
Lookout 6.1: Install Failure, XP SP3
Windows XP SP3, all updates as of today.
Standard Lookout setup with Keyboard Driver.
Will not start install from Lookout CD, error.  From hard drive, fails on ALL components, DataSocket, EULA Depot, etc.
Completely fresh Windows install, all updates. AMD Phenom 2.6Ghz x4, AMD790G, 4GB RAM,1TB RAID5
Installs fine on my SP2 machine.
Need resolved quickly!
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(7,439 Views)
Update:
Lookout 5.1 and 6.0.2 fail also
Tested on SP1 and SP2 machines, similar configs with no issue.
Maybe the MSI installer changed?
Mike
(7,434 Views)
Update 2:
Same computer, SP3 removed, same issue.  No idea now, its a fresh install.
(7,432 Views)
If you double click on Autorun.exe, do you get an error message? Or which step do you get the error on? Give a screenshot of the error.
The SP3 should not be an issue for the install.
Ryan Shi
(7,419 Views)
Autorun fails before the Lookout install splash screen.  Autorun shows, i click "Install Lookout" and it errors out.
Lookout install fails at all components.
Its something wrong in the Windows Installer...  But this is a completely fresh install.  SP3 makes changes to the Windows Installer, but are considered minor.
Mike
Message Edited by Mike@DTSI on 10-23-2008 12:03 PM
(7,410 Views)
Update:  Fresh install of SP2, no issues.
Maybe a new Windows Update messes it up, it was fully patched before install. SP2 with no patches worked fine.  SP2 with all patches works fine.  SP3 it fails.
Version checking?
EDIT:  Microsoft KB952287 check into that one
Mike
Message Edited by Mike@DTSI on 10-23-2008 04:50 PM
(7,403 Views)
I installed a fresh sp3, but didn't see the error.
Did you apply that KB? It doesn't say detail about the problem. Maybe a microsoft KB addressed this problem and you don't have it installed on the computer?
Ryan Shi
(7,389 Views)
