Lookout
Lookout 6.1 crashing when trying to compile .lks file
When trying to compile my .lks file in Lookout 6.1, Lookout crashes. From the event viewer I get the following information on the crash:
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date:  10/16/2007
Time:  1:19:38 PM
User:  N/A
Computer: SCADA-PE-1
Description:
Faulting application cbl.exe, version 6.1.0.27, faulting module lkworks.dll, version 6.1.0.27, fault address 0x000e7377.
Data:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 63 62 6c   ure  cbl
0018: 2e 65 78 65 20 36 2e 31   .exe 6.1
0020: 2e 30 2e 32 37 20 69 6e   .0.27 in
0028: 20 6c 6b 77 6f 72 6b 73    lkworks
0030: 2e 64 6c 6c 20 36 2e 31   .dll 6.1
0038: 2e 30 2e 32 37 20 61 74   .0.27 at
0040: 20 6f 66 66 73 65 74 20    offset
0048: 30 30 30 65 37 33 37 37   000e7377
0050: 0d 0a                     ..
Any assistance on correcting this problem would be GREATLY appreciated, since I will lose a bunch of work I have completed working with the l4p file.
Computer Info: Windows XP SP2 OS, Dell Optiplex GX745, 2.66GHz, 2GB RAM, Dual Core Processor
Thanks!
Jason Phillips
(4,976 Views)
PROBLEM SOLVED!!
Jason Phillips
(4,962 Views)
I'm having the same problem, John.  How did you fix this?
Geoff Klotz
GK Associates, Inc.
(4,822 Views)
Geoff,
Go into your Lookout folder and look for the file "cbl.err". Open that file in notepad or wordpad and you should see where your errors are that are preventing your file from compiling.
I got so used to Lookout generating the errors when a compile failed and displaying them immediately that I forgot about checking this file.
Good luck!
Jason Phillips
(4,811 Views)
