Lookout
Lookout 6.2 Beta
I remember that I met similar problem before on my development computer, but I cannot reproduce it in a certain way.
Do you install DSC besides Lookout in the system? If you just installed the Lookout in a clean OS and run the process for a while, then you saw the problem, I'd like first to reproduce it with a clean machine if possible. Are there a lot of alarms generated by Lookout server? What's the database size? How many traces and how often is the data logged?
A simple server-client process with data logging and viewing doesn't have this problem. I will try to make more alarms and log more data.
I'm not sure if the problem is related to the OS.
Ryan Shi
Message 11 of 13
(3,629 Views)
Hi Ryan,
I'm sorry but I've had zero time to isolate this issue so far.  I do know that the 2 systems affected are running clean installs of 6.2 beta with no DSC.  Luckily, the network goes down very infrequently.  I would like to know if you have any more info on this yet because I would like to expand 6.2 to more critical apps but am hesitant do to this problem.
Ed
Message 12 of 13
(3,516 Views)
Fortunately I reproduced the crash on my computer recently. I don't know whether the problem is only in Citadel 5.6(lookout 6.2), or it has been there for a while.
I notice that the problem is related to a certain database on my computer. After I detach the database, it will not crash. Good news is we can now reproduce the crash by a database.  But we need some time to fix it.
One option for you is try to archive the current database into a new one. I archive the problem database on my computer to a new database, and detach the problem one, then it will not crash after network disconnected. Sorry for this problem.
Ryan Shi
Message 13 of 13
(3,489 Views)
