Lookout
Lookout Client Connections
I am having problems connecting my clients to the Lookout Server. When I install
the client software nowhere does it ask for a server address. So everytime
I run the application on the client it tries to do everything in localhost.
Con someone please point me in the right direction to solve this problem.
(3,644 Views)
You have to connect the objects that are connected to the driver objects to the
server address through URLs or direct connections and delete all the driver objects
on the client aplication. You can also use the link connection object if you
require more flexibility.
Joan LLuch
(From Spain)
(3,644 Views)
