Lookout
Lookout Direct error: "Logos executable has encountered a problem and needed to close."
I'm using Lookout Direct 4.5.1 (build 19) and see the following error after logging in to Windows XP Home:
Logos executable encountered a problem and needed to close.
I created a new process, added a hypertrend object, saved, rebooted, and the error did not occur after the first reboot but started again after subsequent reboots.
I spoke with Automation Direct tech support and they recommended typing the following two commands at a command prompt:
lktsrv -remove
lktsrv -install -manual
I tried this, rebooted and the error persisted.  Any ideas on what else to do here?
Yesterday I had been working on finishing up a project using Lookout Direct and this error started occuring.  I reformatted the computer, reinstalled Lookout Direct and had no problems.  Today the error started again.  The only other software I had installed on this PC was Automation Direct's DirectSoft 5.
The guy I spoke with at Automation Direct said there was once a form or post on NI's site detailing a method to fix this problem but since recent website changes he is no longer able to find it.  Is anyone here familiar with that?
Dave
Message Edited by davey31415 on 04-05-2010 02:15 PM
Message Edited by davey31415 on 04-05-2010 02:16 PM
(7,902 Views)
Here are the error details:
szAppName: lkcitdl.exe
szAppVer: 4.2.0.20
szModName: unknown
szModVer: 0.0.0.0
offset: 0012e7e8
(7,897 Views)
I just tried the -remove and -install -manual commands with lkcitdl instead of lktsrv.  After the first reboot everything seems to be working again.
(7,896 Views)
I saw the Logos executable error twice more and also ran into a "waiting on time service error" when opening Lookout Direct, the latter of which prevented Lookout Direct from opening at all.
In both cases removing and reinstalling the services fixed the problem (reboot afterwards).  If anyone is dealing with either of these errors I'd suggest typing the following into a command prompt (start -> run -> cmd):
lktsrv -remove
lkcitdl -remove
lkcitd -install -manual
You should see a dialog box which requires you to click OK and states that removal was successful after the two -remove commands.
(7,877 Views)
I don't remember if Lookout Direct 4.5.1 already uses Logos 4.5.1. You can try to install the Logos 4.5.1 from http://joule.ni.com/nidu/cds/view/p/lang/en/id/492
Directly run it.
Ryan Shi
(7,862 Views)
I started a thread in Automation Direct's forums related to this error and a "waiting on time service" error that I keep getting when opening Lookout Direct here: http://forum.automationdirect.com/showthread.php?p=32860#post32860
Hope it helps someone in the future.
Dave
(7,855 Views)
