Lookout
Lookout Driver Format
Good day.
I am running Lookout 6.01 and have hit a snag when importing FIX members in from Excel.  Specifically, the format of the FIX driver is different than the format of the MODBUS MOSCAD driver already in lookout.  What I am trying to find out is what the format of the Lookout MOSCAD driver is as well as the format of the FIX driver.
Here is an example of the FIX member I am trying to import  VI:15:3:0
Here is an example of the Lookout MOSCAD member I already have: AI0r0c0.  I am assuming "AI" stands for analog input, the first 0 is the member number, r stands for row, and c for column.
Any and all help is appreciated.
Frank
(3,711 Views)
what's the meaning of  VI:15:3:0?  I think you need to change it manually into the format that Lookout uses. And then import it into Lookout.
Ryan Shi
(3,684 Views)
That is what I am trying to import from Excel into Lookout, the I/O address for a Motorola PLC.  I would change it into Lookout's format, but I don't know how to convert  MOSCAD into Lookout, or how to decipher Lookout's MOSCAD format (per the example I gave in my first post).
Hope this answers your question and thanks for your reply.
F
(3,672 Views)
