Lookout
Lookout OPC Client example for Opto 22 Snap LCSX Controller
I would like to have an example of this, even if it is for a different Opto 22 Controller. Is there anyone available?
(2,968 Views)
Once you have the OPC server working, use the OPCClient object in Lookout. Connect to the server by choosing it in the pull down menu. It couldn't be easier. For more information on the OPCClient object, see the Lookout help.
If your question is about getting the OPC server working, the name of the server is OptoServer. It is supported by Systems22.
Chad Evans
(2,968 Views)
