Lookout
Lookout Version 5.X demo software development link
Could anybody send link for lookout version 5.0 demo software?
Please do needful.
Iftekhar Shaikh
Message 1 of 16
(8,678 Views)
If NI cant, after one of the techs posts, i can provided it. I have 5.1 which is capable of working with 5.0 most times.
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 2 of 16
(8,673 Views)
I cannot find a link for 5.x on website or the ftp.
I have the software, but maybe you need give me an address to upload. If you purchased the software before, you can also contact your local sales.
Ryan Shi
Message 3 of 16
(8,664 Views)
Hi Ryan / Mike,
It is very helpful if you provide Lookout version 5.0.
Please upload Lookout version 5.x to following FTP address. Details are as follows for same.
Address: ftp.transtechprojects.com
User name: guest@transtechprojects.com
Password:  guest123 (case sensitive)
Procedure to Access FTP: If you are using IE-7, please follow below steps,
  1. Type in the FTP address, it will show you an error page.
  2. Then go to menu bar “View à Open FTP Site in Windows Explorer”, this will open another window and a message about denied access will be popped up. Click “OK”.
  3. Then go to “File à Log In as” and log in here with given user id and password.
 If you are using IE-6 then you will have to follow only Step #1 and Step #3 above.
Thanks and regards,
Iftekhar
Message 4 of 16
(8,657 Views)
I failed to open your ftp site, but I uploaded it to ftp://ftp.ni.com/outgoing. File name is lookout5.zip.
It will be deleted in two days.
Ryan Shi
Message 5 of 16
(8,647 Views)
Mike ,
Please provide 5.1 version. It  is very helpful if you provide lookout 5.1.
Thanks  and regards,
Iftekhar
Message 6 of 16
(8,345 Views)
alguien me pude decir porque no puedo crear una pregunta. me aparece un mensaje de que me paso de los diez mil caracteres pero ni al caso, asta le cale nomas con decir hola, y me seguia diciendo lo mismo. por que?
Message 7 of 16
(8,343 Views)
parece que nomas puedo responder. Tengo este problema les envio el archivo adjunto
Message 8 of 16
(8,342 Views)
You can download it from http://joule.ni.com/nidu/cds/view/p/lang/en/id/1316
Ryan Shi
Message 9 of 16
(8,310 Views)
Ryan,
Thanks for reply.
Unable to download.Please do the needful.
Iftekhar
Message 10 of 16
(8,293 Views)
