Lookout
Lookout and Simatic S5 115U CPU945
Hi!
I am trying to comunicate with a Simatic S5 115U
CPU 945, using AS511 protocol.
With CPU 943 and CPU 944, the communications work
fine, but with CPU
945 it does't work at all. The CPU 945 has a S2 communications
port, also
the CPU944 is equiped with the second communication
port.
In Lookout (also BridgeView), when you create the
communication object
AS511, it is not posible to select the CPU type,
only thing that can be selected
is the
unit type (115U, 135U and much more). Nowhere in
the documentation
I could
n't find something about this problem. If
anyone encoutered this problem,
I would
apreciate any help.
Thank you in advance,
Vlad
(3,245 Views)
Have not seen anything else like this.
(3,245 Views)
