Lookout
Lookout development usability suggestions
While I'm posting I thought I would put in a few suggestions for future enhancements/fixes for Lookout
1. Thoughout lookout there are plenty of popup panels, boxes, text entry fields where it seems that the developers have chose the absolute smallest possible window/text entry size in an UNRESIZABLE window....?? For example the popup under Options->Startup, or the 'Alarm Properites' popup when you double click on an alarm or the 'Edit Connections' window....
2. when exporting client processes to a web server why must the client files be in the lookout 5.1 base directory and not from the directory I developed them in? This seems a bit arbitrary and an easy fix.
3. The standard 'button' object has a confirmation popuop optio
n i.e. "Do you really want to press this button?" but I can't find the equivalent on the CWButton object.
(3,158 Views)
Can you please submit your product suggestions to the product suggestion webpage? This link will take you there.
http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
Thank you,
Joseph D.
(3,158 Views)
