Lookout
Lookout does not recognize passwords when attempting access to client process through web
When accessing client process through a web browser Lookout prompts for username and password but doesn't accept valid username and password.
(3,269 Views)
Passwords are unique to each machine not to the application. For example if I were to load your application onto my machine, my security settings would be in place. I have never had Lookout ask for a password when accessing through a web browser. Does the machine you are using have Lookout on it also? If it does, you need to use the user names and passwords for that machine. If not,try using user name "administrator and no password.
Hope this helps,
Carl
(3,269 Views)
You have to load the lookout.sec file from the development computer onto the client computer or else no password is required.
(3,269 Views)
