Lookout
Lookout error 0x0061569e Memory could not be read.
I need help with a Lookout error I get when I change an Alias in Lookout. I make my change, then a while later I get an error that says:
Lookout Application Error
0x0061569e referenced at memory 0x00200066 the memory could not be read
Please select ok to close the application.
Has anyone seen this error before? What can cause it.
Also, if I just restart Lookout, the Trending no longer works until I reboot.
SCADA Programmer at the Coachella Valley Water District.
(6,638 Views)
What's version of lookout?
Does it crash every time you edit the Alias?
Ryan Shi
(6,623 Views)
Its an older version.
Yes, it crashes every time after a few minutes.
(6,617 Views)
Can you create a new one with expected configuration and different Alias name? And then edit the .lks file by notepad, find and replace all the old alias with the new alias. So the new Alias will work and you can delete the old one.
Before you edit the .lks file, backup it first.
The problem looks like a known issue. We did fix it but I'm not sure if we have fix for your version.
Ryan Shi
(6,599 Views)
Thanks for the help.
Is it true that if you don't set up any special Graphics or write to any files, the minimum recovery in case of a failure would be
all of the .l4p, l4t, .lka and .lks files, also the Lookout.ini and the Database Folder. Of course after you re-install Lookout. Does that sound right?
(6,591 Views)
Yes. All the process files, and ini file, and database folder.
Ryan Shi
(6,544 Views)
