Lookout
Lookout & msvcrt.dll
I am running Lookout 4.0.1. I have a Primary Server, a Standby Server and
7 Clients on an Ethernet Network. My network also has 8 Allen-Bradley SLC
5/05s. When I run my application on my Primary or Standy Server, everything
runs fine. When I try to run my application on any of my Client computers,
I get an Application Error in file "msvcrt.dll" . HELP!!!
(4,029 Views)
and>7 Clients on an Ethernet Network. My network also has 8 Allen-Bradley
SLC>5/05s. When I run my application on my Primary or Standy Server, everything>runs
fine. When I try to run my application on any of my Client computers,>I
Mike,
The page fault in MSVCRT.dll has been found to occur when the network settings
for the computer have irregularties to them. These irregularities include:
A) Computer Name (Control Panel--> Network Settings--> Identification Tab)
starts with a number
B) Computer Name (Control Panel--> Network Settings--> Identification Tab)
contains non-standard characters suc
h as ',%,#, space, etc...
C) Computer Name (Control Panel--> Network Settings--> Identification Tab)
is too long
D) Computer Name (Control Panel--> Network Settings--> Identification Tab)
does not match host name in DNS settings (Control Panel --> Network Settings
--> TCP-IP Properties --> DNS Configuration Tab) (Note: This will occur even
if DNS is disabled. You should enable DNS, type the correct name, than disable
DNS.
Aaron Gelfand
(4,029 Views)
