Lookout
Lookout operating system
Will Lookout 6.2 install and run on a Windows 2003 Server?
(6,624 Views)
Without any direct response, we nevertheless installed LookOut on Windows Server 2003 and it worked flawlessly from day one for about a week now.
(6,577 Views)
Hi Laurin,
If you search the forums, you'll find lots of references to Lookout running on Windows Server 20xxI had server and combo-server/client processes running on Server 2003 for many years and still have a client process running on same with no issues.
I would encourage you to move to Server 2008 for even more stabilityLookout also works quite well on virtual machines under Hyper-V included with Server 2008 (Server 2008, Windows Vista or Windows 7 guest OS's, 32 and 64-bit tested...all work great with few limitations/complications).
Good Luck!
Ed
(6,551 Views)
