Lookout
Lookout's Modbus Slave Address
It appears that the Modbus Slave (Ethernet) Object in Lookout (6.0.1) doesn't work with an Address (or "Identifier") greater than 127.
I tried a simple test with the Modbus Object in one process with an address of 128.  And a ModbusSlave Object in another process with its address as 128.  There's no communication.  However, when I make the addresses 127 (or lower), they yak like nobody's business!  Smiley Very Happy
I haven't tested the Serial version though.
Est-ce un bug?
-Khalid
(3,770 Views)
Hi Khalid,
I just tried to recreate the scenario. I used computer running Lookout 6.0.2 and created a modbus slave object which was connected to a pot object to change values. On a different machine running the same version of Lookout, I created a modbus object and I was able to read data from the modbus slave object. I tested the indentifier values from125 to 255 and they work fine. The objects do not accept values greater than 255 which is as expected. Is there more configuration information that I am missing?
Prashanth
(3,757 Views)
Hi Khalid,
I think I was overlooking the Lookout 6.01 version that you mentioned earlier in your post Smiley Happy ! I was able to recreate the issue that you are facing if I create a modbus slave object in Lookout 6.01 version. Thats a bug! And version 6.02 has a fix for it! Smiley Very Happy
Have a great day!
Prashanth
(3,754 Views)
Thank you Prashanth.  Just downloaded 6.0.2.  And ModbusSlave Addresses > 127 work fine!
-Khalid
(3,746 Views)
