Lookout
LookoutDirect drivers "vs" Lookout drivers
Have just upgraded from LookoutDirect(a limited version of Lookout -500 I/O points max and limited drivers)  to NI Lookout 6.0.2.  I need to have two  DirectLogic PLC's communicate with the same Lookout process. One PLC is located remotely and has fiber optics between the pc running Lookout and the Plc. The other PlC is within ten feet of the Pc. The Lookout Direct software had a driver for an ECOM card supplied to LookoutDirect from Host Engineering. Can I import this driver in to Lookout? Any help appreciated.
(3,679 Views)
The modbus driver supports modbus tcp, which can be used with an ECOM card.
Also, the DLPus.cbx file can be used with the DirectSoft OPC server
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(3,673 Views)
the ecom driver for lookout is in the directlogic plus package from ad.....
(3,657 Views)
