12-26-2011 01:16 PM
I am trying to send an email from Lookout V6.6 using the Mailer object. I have an email address setup through GMAIL and have verified it works. Also, Lookout Mailer object is able to verify GMAIL server. I get the following error message when trying to send the email: "SMTP: invalid from address. SMTP error 530 5.7.0 Must issue a STARTTLS command first. d5sm35857280yhl.19". Anyone know what is causing this?
12-28-2011 07:04 PM
Lookout mailer object doesn't support TLS(Transport Layer Security), however the Gmail requires it. You need to choose another mail server. As far as I know, Gmail, Live and Yahoo requires the TLS.
12-29-2011 05:04 AM
Ryan,
Thanks for your response. I ended up using another email account that does not require TLS. Is there a reason Lookout does not support TLS? Other SCADA applications do. Any plans to add this support?
Bill
01-05-2012 03:33 PM
Another method is to use a SMTP relayer, we have deployed them in the past.
http://www.hmailserver.com/index.php?page=welcome
Mike
