Lookout
Microsmart/Pentra - problem with numeric expression on data registers
Noticing problem with numeric expression on data registers D10 and above with IDEC Opennet drivers with microsmart/pentra... are their updated drivers for the microsmart/pentra?
(5,883 Views)
We have updated driver in NI OPC Server that is shipped with lookout 6.2 or later.
If you don't have lookout 6.2 or 6.5, and if you want to test its funcationality, you can download the NI OPC Server from here
https://www.ni.com/en/support/downloads/software-products/download.opc-servers.html
Lookout uses the OPClient object to connect the NI OPC Server.
Ryan Shi
(5,869 Views)
I am currently using Lookout 6.5 that I am having this problem. It may be that trying to communicate with the plc from maintenance port 1 and having port 2 in Modbus Master. Trying to have Lookout at as a secondary system / viewer of plc status. Just can not seem to get Lookout to be ably to view Data from Date Reg. Above the D10 Range. Looks like a may drop the idea of keeping the Plc as a Master / Slave system that is currently working, and having program Lookout to control and View I/O on plc units.
(5,854 Views)
