04-01-2007 05:47 PM
04-02-2007 11:20 AM
Hi Pedjasns
We're currently looking into your issue here at NI UK & Ireland. I have found some previous queries on this subject by other Lookout users and it seems that unfortunately there is no direct conversion tool. This means that in order to perform the conversion, you must therefore perform hardcode implementation. I will continue to look into this for you and hopefully we will be able to come up with some method of performing such a conversion. If possible, it would be of benefit if you could attach your program to a post here. Alternatively, I will send you an email with which you can reply if you would prefer to keep your program off the forums..
Hopefully we can come up with some form of a solution!
Thanks for contacting NI
Best wishes
Rob
04-02-2007 01:04 PM
04-03-2007 05:39 AM
Pedjasns,
I have sent an email to your account. By replying to that email, you can send your code directly to me.
Many thanks
Rob
04-04-2007 05:03 AM
04-04-2007 06:57 AM
Pedjasns
Have sent email to that email address. Hope you get it ok.
Many thanks
Rob
04-05-2007 04:30 AM
HI predrag
Thanks for sending the program over, i've had a look at it and I can see what you're trying to do. Unfortunately, myself and my team have been unable to develop any practical hardcode for you to utilise, I was only able to come across some information from a previous Service Request which occurred in the US. The text details some hardcode written by an AE for a customer who was having a similar problem to you. The attached information might hopefully be of use to you, I just apologise that we were unable to develop a full solution. Also, the following links might also be handy.:
http://zone.ni.com/devzone/cda/tut/p/id/3381
http://zone.ni.com/devzone/cda/epd/p/id/835
There is however and alternative. You mentioned in a previous post that you were an experienced LabVIEW user and that you only have an evaluation version of Lookout. It might therefore be of more use if you were to develop your program in LabVIEW which has MODBUS facilities. I have found some very good information on how to develop these kind of applications, just copy the following links in to your browser. The first URL links directly for the MODBUS library installer for LabVIEW version 8.x.
http://sine.ni.com/devzone/cda/epd/p/id/4756
http://digital.ni.com/public.nsf/allkb/64D9902E8B9AE4AF8625712D0076B463
http://zone.ni.com/devzone/cda/tut/p/id/2956
http://zone.ni.com/reference/en-XX/help/370246E-01/lvdschelp/creating_modbus_io_server/
I apologise once more for not being able to give you a full and viable solution, I really hope the information I have provided here can be of use to you.
Best wishes in the continuing development of your programs
Rob
04-05-2007 08:01 AM
04-05-2007 08:14 AM
Pedrag
thanks for the feedback, it's always appreciated. The service request automatically generated by these forum posts are utilised by our R and D engineers for future development. Therefore, this problem may well be encountered and hopefully, rectified.
Many thanks for contacting NI
Best wishes Pedrag
Rob
