Lookout
Multiple DL-06 controls to one PB
I have six DL-06 that communicate back to one P.C. with a central touch screen control. I need to use one Pb to control, for example DL1.C0 and DL2.C0 and DL3.C0 and DL4.C1 etc. Is this possible? What data members am I looking for or what syntax should I be using in the Pb URL box? Any help will be appreciated. Thank you.
(3,930 Views)
In Object explorer, "edit the connection" of driver object. Connect DL1.C0 to Pb.value, DL2.C0 to Pb.value ......
BTW, which object are you using?
Ryan Shi
(3,922 Views)
Thank you for your reply. I was mistakingly trying to connect Pb1 on my Lookout Direct panel to the PLC element (DL1.C0, DL2.C0, etc) instead of connecting the PLC element to the push button on my control panel. Also I had my Pb1 as a remote positon source instead of a local source. Your post got me thinking in the right direction. Much appreciated!
(3,915 Views)
