Lookout
NIHypertrend in report degraded
HTML Report which contains three separate NIHypertrend active X objects (size 800x300 pixels) is generated.
Looking at the finished report, what happens sometimes is that NIHypertrend unexpectedly shrinks from 800x300 down to 100x100  graph area
which is positioned in the left upper corner, where the rest of 800x300 object is just filled black.
It happens the same to all of the three NIHypertrends when the report is created.
Before report is created, in NIHypertrend.properties.refreshed connection is true for a second.
Any suggestions how to fix this problem?
(3,393 Views)
In which way do you add the hypertrend to report?
I connect hypertrend.graphic to report.display. When the report is created, there will be an html file and a bmp file. The bmp file is the hypertrend. So, in the html report, there are no more hypertrend objects, but only some pics. If the pic shrinks to a small one in report, you can check the bmp file if it is still of the right size.
And also you can check if the bmp is black. If it is, the hypertrend in report should be black.
Message Edited by Ryan.S on 09-21-2006 09:45 PM
Ryan Shi
(3,375 Views)
