Lookout
NOTIFYING CLIENT COMPUTERS OF SERVER ALARMS
I am developing a run-time enterprise system with for clients. I can't seem
to maximize the alarm window (viewing all server process alarms) in the
client machines when a there is a new alarm. I have tried using the
"$alarm.update", but I have no luck. Please help.
I must also trigger a playwave object with new alarms.
Bill Sheats
(3,617 Views)
Bill,
I just tried connecting $alarm.activatePanel to $alarm.update and it worked
fine (4.0.1.51). This works for the playwave too. If, for some reason,
$alarm.update doesn't work, you could always try sampling $alarm.active and
when the sample changes, you can activate the panel. The "update" datamember
should work, though.
Brian
"Bill or Allison Sheats" wrote:
>Hi,>>I am developing a run-time enterprise system with for clients. I can't
seem>to maximize the alarm window (viewing all server process alarms) in
the>client machines when a there is a new alarm. I have tried using the>"$alarm.update",
but I have no luck. Please help.>>I must also trigger a playwave object
with new alarms.>>Bill Sheats>>>
(3,617 Views)
