Lookout
Need to Upgrade from Lookout 3.8 to 5.0?
I have a customer that would like to upgrade from Lookout 3.8 to Lookout 5.0. Are there any special considerations that I need to take when doing this upgrade? There are a couple of versions skipped. Is this O.K.? Or do I need to go from 3.8 to 4.5 to 5.0? Or should I just purchase the 5.0 Package? How about the database? Will the data be compromised?
(3,171 Views)
You can move directly to LK 5.0, convert the process and convert the DB.
There are some special things to keep in mind and are covered in the Dev Zone article "Converting Lookout 3.8 Processes to Lookout 4.5." Follow these guide lines but this will take some time depending on the size of the process. If you only have LK 3.8 programming experience, spend the time reading the Help files because there are massive advancements in the programming environment. You will save time by reading them first, rather than later after hours of work.
LK 3.8 DB's are not compatible with LK 4.x DB's. Lookout 5.0 came out with Historical Data Viewer to view your DB's and has the ability to convert a 3.8 to the new format. Follow KB article "Using the Citadel Database with Lookout
5."
(3,171 Views)
