Lookout
New Version Suggestions
I see my "Lookout" beta link reappeared on ni.com/beta, but no updates on the site yet....Smiley Sad
How about some alfa testing on production systems? Smiley Very Happy
Message 41 of 48
(3,804 Views)
Feature Request/Improvement:  On the TextEntry Object add a small icon to bring up the Virtual Keyboard.  Touchscreens dont have "right click", and using the left click requirement is "confusing" for some operators.
Vector graphics would still be welcome :smileywink:
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
Message 42 of 48
(3,639 Views)
Back to life:
Process parameters: The $system object gives username, time, etc.  Make the processes parameters visible.  Database information would be very useful, make setting the Citadel object easier as well.
Panel parameters:  The Height and Width members are static.  Making them show the actuall current width would be great.  I have a panel maxed (1650x1080) yet it still shows 518x409 for the members.
ActiveX Methods:  Basic support for methods, make it like property.  write to method (ex: ocx.propertires.method=""TextValue",NumValue"), and reading exp1=ocx.properties.method.  Obviously only the simplest of controls would work, cant return arrays, referenced objects, etc.
Previous suggestions would be nice too 🙂 (TextEntry virtual keyboard button, zoom, vector graphics, etc.)
Mike
Message 43 of 48
(3,385 Views)
I would like to see the interface for the edit connections, edit database and connection browser improved.
Simply being able to show all of these windows at the same time and being able to sort them would be a huge improvement.  I would definitely purchase an upgrade for an interface which integrated all three of these together.
Dave
Message 44 of 48
(3,162 Views)
- we are also in the requirement of the multi-screen display. It should be defined in the setting of the panel that on which screen it is to be displayed.
- There should be a verification object, through which at some stage the verification message/confirmation can be get confirmed from the operator.it should be with the data members as
Logical expression - on the occurance of the same the message to be diaplayed.
Message - to be displayed for the operator for confimation.
Logical value - Through which the operator can confirm/verify the displayed message.
Message 45 of 48
(2,374 Views)
TextEntry, Pushbuttons and switches all have a verify member?
Forshock - Consult.Develop.Solve.
Message 46 of 48
(2,358 Views)
Hi Mike,
Thanks for your reply.
You are right that the text entry, pushbutton and switches have the varify memeber. But it is displayed only when all these objects are operated directly from the panel screen.
in case they are operated through the data memeber connection then the verification message is not displayed. For all these obejects this functionality is ok.
the problem is only when at some stage in the batch cycle a confirmation is required to be verified from the operator. Currently i have created the same by using objects panel, text entry and switches. But could not able to have all the functionality.
Message 47 of 48
(2,350 Views)
Feature Suggestion: Serial Tunneling over IP
With fewer and fewer machines featuring serial ports, the ability to support legacy equipment can be compromised.  There are "virtual port" programs for ethernet adapters, but I have had mixed luck with them.  I think the ability to tunnel there serial protocols (modbus primarily, but others too) over Telnet would be great as most Ethernet-Serial adapters support this.  (PS:  ClearSCADA supports this)
Message 48 of 48
(2,254 Views)
