Lookout
OPC Client Problem
Hi
I am having problem in configuring opc client. The way I configure OPC Client is given below
Create a New Project
Creat a New OPC Client I/O Server.
Select the appropriate server from the list.
OPC Server will be created.
Right click on OPC Server and select Deploy all.
Right click and then select create bound variables.
I have tried this procedure but no success. Once I managed to view the Tag names of Channels present on the server but values were never transported to opc client from the server.
I have also tried distributed System Managment for the removal of variables before creating any new opc server.
Moreover OPC QuickClient works perfect which shows that OPC Server is right. So now there are some settings in Labview. PLease help me out in solving this problem. Have a look in the attachment picture.
(7,250 Views)
Is the OPC Server on local computer?
You can configure a diagnostic log file in OPC Client's property. Deploy the library and a opc communication log file will be created. post the log file here.
I also suggest you to post your problem in LabVIEW forum.
Ryan Shi
(7,213 Views)
Hi Ryan,
PLease find the diagonistics report in the attachments.
(7,205 Views)
There are some errors when validating items. It's not sure if the problem is in DSC or OPC Server.
Do you know where I can download the OPC Server? It's good to have an evaluation server.
Ryan Shi
(7,202 Views)
Hi Ryan,
I am using OPC server of Third Party and treating Labview as an OPC Client. NI OPC Server works OK on my system .But that third party server has given me those errors.
(7,198 Views)
I tried to get something more from the log file, but it just tells me the errors. I cannot figure out which one has the problem, DSC or OPC Server, and why.
It looks like a problem in OPC Server. DSC gets the data ID from OPC Server, and immediately use this data ID to validate and got the data ID syntax error.
So I want to know if the OPC Server has an evaluation version that I can test with DSC on my computer. I can also use the OPC test tool from OPC foundation to test the OPC Server. What's the name of the OPC Server?
Ryan Shi
(7,188 Views)
Hi Ryan,
That OPC server is dongle protected having no evaluation version. I have attaced a picture in this reply running OPC Free Client in background AND LABVIEW running at front. You will notice that Free OPC Client  shows good signal quality and Labview showing error.
OPC Free client is shiped by NI.
(7,181 Views)
