Lookout
Object display get lost from the screens
we are using the lookout 6.5 in server-client architecture and facing the problem that sometimes the display from the panel is geting lost. in edit mode we can select the expression display at the location where the display was placed. but it is not displaying the graphics which was associated earlier with that. Please comment what could be the reason for that.
Message 1 of 8
(6,751 Views)
Do you hve a screenshot or LKS?  What DataMembers are you looking to adjust?
Mike
Forshock - Consult.Develop.Solve.
Message 2 of 8
(6,737 Views)
hi mike,
please find the attached screen shot for the missing display.
The same issue was observed earlier also. in that all the display on one type graphics was missing from one screen.
Message 3 of 8
(6,729 Views)
You said that the Display Properties show a blank/null for the state?
Message 4 of 8
(6,717 Views)
Yes in the display property the custom display is selected and graphics for on and off is blank.
Message 5 of 8
(6,705 Views)
So they wont change to a graphic at all?
Tried deleting the expression display and recreating?
Message 6 of 8
(6,674 Views)
when this problem was arised, i just have associated the display agin with these expressions and working fine. but my concern is to find out the reason, as every time its not possible to check whether all the graphics on all the screens is available or not.
Message 7 of 8
(6,663 Views)
i am frequently facing this problem please suggest the solution.
Message 8 of 8
(6,338 Views)
