Lookout
Objects and graphics reusability
Hello all.
I am new to Lookout, I have used other SCADA and HMI software, so I
wondered about the possibility of reusing objects between screens. I tried
to copy an object from a different process file and it says it is not
possible. What if I want to use a standard control panel in my applications,
such as an About dialog?
Thanks in advance.
(4,224 Views)
Yes you can do this, and the methods differ depending on what version of Lookout
you are using. There is a knowledge base article on the subject.
"Everardo Hernandez" wrote:
> Hello all.> I am new to Lookout, I have used other SCADA and HMI
software, so I>wondered about the possibility of reusing objects between
screens. I tried>to copy an object from a different process file and it says
it is not>possible. What if I want to use a standard control panel in my
applications,>such as an About dialog?> Thanks in advance.>>
(4,224 Views)
