Lookout
Omron OPC Server with Lookout 5.0
I am trying to set up a Lookout 5.0 application using the OPC Client, connecting to the Omron OPC server, CX ServerOPC. When I add the OPC Client, I find the server on the drop down list, but when I click 'OK' to create the OPC client object, once it connects to the OPC server, Lookout crashes. I get the message that Lookout.exe has encountered a problem and has to close. Has anybody used this server before and seen this problem? Any hints as to what could be incorrect in the client or server settings?
(3,789 Views)
What happens if you connect to the Omron OPC server from the National Instruments Server Explorer? Do you access to the OPC items succesfuly in Server Explorer?
Please also check the Tutorial linked below:
http://zone.ni.com/devzone/conceptd.nsf/webmain/B0CC5FE5CBC5727F86256808006AD802?opendocument
Hope this helps.
Best Regards,
Remzi A.
(3,789 Views)
Yes, I can connect to the Omron OPC server from the National Instruments Server Explorer, and can successfulyy access the OPC items in Server Explorer. Server Explorer works well, but I can't create an OPC client connected to the server in Lookout, without Lookout crashing.
Any other advice would be appreciated.
(3,789 Views)
Sounds like a bug in Lookout to me. Is the Omron server a free-download for others to try?
Khalid
(3,789 Views)
I have found out that Lookout versions below 5.1 are only OPC version 1 compliant, while the Omron OPC server is OPC version 2. This is what caused the incompatibility between Lookout version 5.0 and Omron OPC server. It works properly with Lookout version 5.1.
(3,789 Views)
