Lookout
Outputs spiking randomly
I have a system that is running Lookout 6.7.1 with Zetron 1700 and 1716's. I have a couple Outputs that are tied to 2 different inputs in edit connections. They track fine then all of a sudden spike up or down randomly on the HyperTrend. It has been confirmed that the outputs are actually doing this. Just wasn't sure if I have a setting in Lookout that could be causing this. They had an old Ultrac system that worked fine. I feel like I am missing something in a setting. Any thoughts?
Message 1 of 1
(3,035 Views)
