Lookout
Panel print to Acrobat X Professional Hangs
Upgraded to Acrobat Pro X on Win7 x64 machine (was previously Acrobat Pro 9, with no problems) and now Panel prints will no longer complete (acrobat pop-up progress window hangs at ~75%).  Lookout hard crashes from this hang (must reboot, process kill in task manager will not kill Lookout properly).
This is nasty.  Any hope?
Ed
(5,879 Views)
I had the same problem, except no crashing, it just would not generate any .pdf files.  My program worked fine and could print to pdf no problem with Acrobat 9 Pro, but when upgraded to Acrobat X Pro would no longer print.  I talked to Adobe tech support and they said they only support Microsoft Office and AutoCad for third party compatibility.  They said it was a bonus that LabView worked with Acrobat 9 and were not concerned or surprised that it doesn't work with Acrobat x.
I ended up using the CutePDF writer which is freeware and seems to work well for LabView 2011 on 64 bit Windows 7.
--AOD
(5,736 Views)
