Lookout
Password changed and forgotten. How to get logged on without it?
Cannot login to LookOut screen because somebody has changed the password. I am the administrator and would like to reset to a password of my choosing.
(3,759 Views)
You may want to call NI's Technical Support for this.
Khalid
(3,759 Views)
You could replace the lookout.sec file located in the system32 directory with the one I have attached, it is the default as installed by Lookout. You would lose your logins that you have defined, but it should grant you access using full administrative rights.
(3,759 Views)
