Lookout
Path in Lookout
In my application I have a Spreadsheet object I want that generates a file outside of lookout folder: in C:\Production\Shift.csv. This computer is connected to a LAN with more drives (J:, I:, H:, etc).
What path should I type to save the data? Should I use the Computer name instead of "C:"?
(3,609 Views)
23r23,
the path:
"\\otherpc\sharedfolder\filename"
Remember to check permission and user on the other pc,otherwise you wil get an "access denied" error.
JSS
(3,609 Views)
I see I didn't explain well. I need to log the data in the same computer that lookout runs, but in its C drive. Because this computer is connected to the LAN, I want to make sure I'm logging into the computer and NOT on other of the network.
Again: How to make the path to the C drive into the same computer?
(3,609 Views)
By default, lookout uses its own main path, so if you want to log in the C drive in the same computer, just use "c:\SomeFolder\filename"
JSS
(3,609 Views)
