Lookout
Printing a Hypertrend from Lookout 5.0
Is there any way to print out a hypertrend?
(2,906 Views)
Here is one way - if you create a pushbutton and place it on the panel with the hypertrend. Then "edit connections" of the panel to the print data member. What prints out will be the panel from upper left corner (0,0) to the lower right corner (width, height in the panel properties). If you place the trend in the upper left corner and adjust width and height accordingly, only the hypertrend prints out. Since that is sometimes difficult, I copy the hypertrend to a panel with nothing else on it (it is used only for printing). One downside from this method - you do not get the hypertrend cursor popup panel. To get that included you will need a screen capture & print program such as SnagIt.
(2,906 Views)
