Lookout
Problem installing fpoint.cbx fix on 4.0.1 build 51
Hi,I need to monitor the status of the FP-RLY-420relays (KnowledgeBase document 1WJGALPS).I replaced the original fpoint.cbx by a fixtaken at ftp://ftp.ni.com/support/lookout/Lookout4fixes/fpoint.cbx.and the Fieldpoint object disappeared from Object/Create/Select objectclass/Dirvers dialog.Then I placed the original fpoint.cbx back and it works fine again.Could you please advise how can I install the fix.Best Regards,Sergei ModebadzeTOMA.
(3,824 Views)
Hmmm...try to remove lookout.dat before run lookout.
Alexander
toma.inc@usa.net wrote:
>>>Hi,>
I
need to monitor the status of the FP-RLY-420>
1WJGALPS).>
I replaced the original fpoint.cbx by a fix>
taken at
href="ftp://ftp.ni.com/support/lookout/Lookout4fixes/fpoint.cbx">ftp://ftp.ni.com/support/lookout/Lo...
and
the Fieldpoint object disappeared from Object/Create/Select object>
class/Dirvers
dialog.>
Then I placed the original fpoint.cbx back and it works fine again.>
Could
you please advise how can I install the fix.>
Best Regards,>
Sergei Modebadze>
TOMA.>
(3,824 Views)
It doesn't work. Still there's no FieldPoint driverin Object/Create window.Best Regards,Sergei  Alexander Kuzmin wrote:Hmmm...try to remove lookout.dat before run lookout.Thanks,Alexandertoma.inc@usa.net wrote:>>>Hi,>
Ineed to monitor the status of the FP-RLY-420>
relays (KnowledgeBase document1WJGALPS).>
taken at ftp://ftp.ni.com/support/lookout/Lookout4fixes/fpoint.cbx.>
andthe Fieldpoint object disappeared from Object/Create/Select object>
class/Dirversdialog.>
Couldyou please advise how
Best Regards,>
Sergei Modebadze>
TOMA.>
(3,824 Views)
Sergei,
I check this situations and I can't reproduce this problem. This is my configuration:
Lookout 4.0.1 Build 51. Original FP cbx: size 109568 bytes, Data Modify.
Fri Jan 28 22:37:54 2000, cbx version Lookout 4.0.1.51. FP cbx from ftp size:
size 122937 bytes (please check this size to be sure this file was broke
during download), Data Modif: Fri Nov 03 15:06:26 2000, cbx version: Lookout
4.0.1.53.
If you have the same numbers please let me know and I will try to help you.
Alexander
(3,824 Views)
Alexander,Your colleges already managed to help me inresolving the problem.There was a wrong cbx file on the ftp (123140 bytes dated10.09.00). The file you are talking about (modified today)works OK. Obviously your colleges put it on the ftp earliertoday.Everything is fine with this issue now, so thank youvery much for your help.Regards,Sergei Alexander Kuzmin wrote:Sergei,I check this situations and I can't reproduce this problem. This is my configuration:Lookout 4.0.1 Build 51. Original FP cbx: size 109568 bytes, Data Modify.Fri Jan 28 22:37:54 2000, cbx version Lookout 4.0.1.51. FP cbx from ftp size:size 122937 bytes (please check this size to be sure this file was brokeduring download), Data Modif: Fri Nov 03 15:06:26 2000, cbx version:
Lookout4.0.1.53.If you have the same numbers please let me know and I will try to help you.Thanks,Alexander
(3,824 Views)
