Lookout
Problem with Lookout Recognizing Fieldbus Network
Hi,  I'm trying to log some data on a Fieldbus network using Lookout's Data Logging capabilities.  The problem I'm running into is that whenever I open lookout and try to have Lookout talk with the Fieldbus network, it doesn't display any of the fieldbus drivers in the object explorer.  I'm using NI-FBUS PCMCIA and the newest version of Configurator.  I've tried deleting the Lookout.dat file just as the help file tells me but still no dice when i open Lookout back up with the Fieldbus network running.  The Fieldbus network works just fine.  Configurator tells me that all devices are working and in the Auto Mode and displaying relevant values.  I'm kinda stuck and would appreciate any help in this matter.
(4,893 Views)
Create OPCClient object in Lookout. The Fieldbus OPC server is called NIFB_OPCDA.3. Then you should see the connected devices.
Ryan Shi
(4,886 Views)
It works!  Hooray!  Thank you Very Much!
(4,874 Views)
