Lookout
Problems publishing a process to the web with 4.5 (12).
I have been tring to publish a process to the web for several weeks. I am running 4.5(12) at the server and web client. I do get partial connection, but any custom .WMF graphics do not show up. Also I am not getting a connection to the server. I get the red "X" through all of my connections, allthough I do get my meter readings at first just before the "X" show up. The symbolic link is using the IP address and not the machine name (per Net. Inst.).
The possible solution is to run 4.5(13), but this would be the third update, and having to change the server and all clients is a pain. If it works I'll do it, but I do need to know if it is the answer.
Any help with this would be appriciated. Thanks, M
ark
(3,062 Views)
There are two main KnowledgeBase entries that discuss issues with the web client. Check them out and see if they correct your problems.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/dbdcd29f28fdc341862569dc00788d7c
http://digital.ni.com/public.nsf/websearch/BE15FB343C2E9BA4862569DC007AC900
(3,062 Views)
