Lookout
Problems when editing Hypertrend graphs
Yes, I will also add hyper.cbx into 6.0.2 updates.
The lkworks.dll and lookout.exe fix the bugs in Lookout 6.1. If you are using 6.0.2, you don't need them and you can't use them.
Ryan Shi
Message 11 of 15
(2,639 Views)
Has this problem been solved in Lookout 6.2?
Message 12 of 15
(2,369 Views)
Accepted by topic author kenv
Yes, I believe the fix has been added to lookout 6.2.
Ryan Shi
Message 13 of 15
(2,353 Views)
We are running Lookout 6.1, Windows XP, SP3.  We recently copied our process to a standby computer.  The standby computer will not run the Hypertrends.  Everything else is working but the hypertrends show no lines.  When the numerical expressions are connected to a point, for example, flow, the digital display is displayed properly.  When the hypertrend is connected to the same output, it does not appear.  I have rebuilt the hypertrends from scratch and copied them exactly from the original, (working), computer and have had no luck.  Any suggestions.  Thanks
Message 14 of 15
(1,606 Views)
ask Ryan for the updated cbx  (ryan.shi -@- ni.com)
I think 6.2 should have been a free upgrade for 6.1 users, but that is in the past.
Forshock - Consult.Develop.Solve.
Message 15 of 15
(1,583 Views)
