Lookout
Problems with Lookout 5 installation
Please Help,
I have both LOokout 4 and Lookout 5 installed on control computer with Windows 2000.  Both previously worked fine.  System required software and servicepack updates.  Now version 5.0 will not function.  Attempted to uninstall and reinstall with original CD.  After installation and registration, attempt to run Lookout 5.0 exe.  When doing this, obtain error that "dynamic link library llworks.dll could not be specifed in path ...".  The .dll files are in the version 4.0 folder; if attempt to copy to 5.0 folder and run, obtain error "ordinal 3730 could not be located in the dynamic link library lkworks.dll"  Any help would be greatly appreciated.
(2,966 Views)
Hello MattUD!
The problem you are describeding is a known issue when installing Lookout 5.0.  The link below explains the error and how to fix it.  Have a great day!
Allan S.
(2,957 Views)
