Lookout
Process Lookout is high when load a new aplication
Each time that make a change in my application and then reload the code in Lookout, ive got a big problem. The process lookout.exe start to increment memory up to 80 o 100Mb and cpu is very high. Sometimes, after ~50 minutes the process is normalize but not another times. The application issue many variables that comes from link of radio modems.
(4,067 Views)
Does the high cpu usage happen after you open lks file and before you see the panel?
Or does it happen after you can see everything?
Which version of Lookout do you use?
If you don't change anything, will the problem happen each time you open it?
Ryan Shi
(4,036 Views)
I can see everything, the application is ok but the cpu is high. I’m use lookout 5.1. Whit or without change, happen the same.  I saw that when polling a port the cpu is high, after 1 hour, polling stop (no more datas) and the cpu is normal. The port polling 15 modbus.
(3,987 Views)
which windows process has the most CPU usage, are you using data logging into Hypertrend or NIHypertrend active X object?
(3,771 Views)
