Lookout
Process file becomes unresponsive when run on Lookout 6.7
The attached process file was developed using Lookout 6.1 which ran on a windows vista computer.  That setup ran flawlessly for many years until the computer started having problems.  I recommended that a new W7 computer be put into service to run the process.  After many attempts, Lookout 6.1 refused to install properly on the W7 computer (sql server service pack upgrade problem).  Anyway, I then recommended upgrading to the newest Lookout, which turned out to be Lookout 6.7.  While the purchase of software and hardware was underway, I pulled a W7 32bit computer with Lookout 6.6 out of its normal duty to run this process and it ran flawlessly.  Lookout 6.7 arrived and was installed in a new W7 32bit computer.  The process loads into 6.7 okay but after a while, Lookout 6.7 becomes unresponsive.  I've tried to figure out why it runs on 6.6 but not 6.7 but haven't been able to narrow it down.  I'm hoping someone can test the process to see if they have a similar experiece.  Any help or ideas would be appreciated.  p.s. the process will look kind of messy because you won't have some of my graphic images.
Joe C.
Message 1 of 1
(5,455 Views)
