Lookout
Process file starts minimized
When staring Lookout, the lookout screen is o.k. but the auto load process file starts minimized.
Lookout Direct 4.5.1.19
XP-Pro
I need the process file to be maximized when the program starts.
Thanks.
(3,081 Views)
Go into Edit >> Connections for the panel you want to be maximized, and set the 'activate' member to 'true'.  The connection would look like this, for Panel1:
Panel1.activate= true
This will maximize the panel on load.
-Khalid
(3,072 Views)
