Lookout
Recipe.xls - loading
Is it possible to load the Recipe file (.xls)
programmatically?
Sergei
(3,773 Views)
Sergei -
Right now, it's not possible to programmatically reload the Recipe file.
Do you have your system set up so that the xls file is automatically updated?
Sergei wrote:
Is it possible to load the Recipe file (.xls)programmatically?
Sergei
(3,773 Views)
Andrew,Thanks for your reply. Yes, I thought of settingup the system to automatically reload Recipefile when it's updated. Basically I tried to usea Recipe file like a sort of 'ini' file to keepsystem settings, constants, etc.SergeiAndrew Monat wrote:Sergei -Right now, it's not possible to programmatically reload the Recipe file.Do you have your system set up so that the xls file is automatically updated?Sergei wrote:Is it possible to load the Recipe file (.xls)programmatically?Sergei
(3,773 Views)
As you might've discovered, the DataTable object in Lookout can do everything
that the Recipe object does.. plus more! It's just not as simple to use
as the Recipe object.
Using it, you can programmatically import XLS files and build a custom recipe
system.
Khalid
toma.inc@usa.net wrote:
>>>Andrew,>
for your reply. Yes, I thought of setting>
reload Recipe>
file when it's updated. Basically I tried to use>
a
Recipe file like a sort of 'ini' file to keep>
etc.>
Sergei>
Andrew Monat wrote:>
Sergei ->
Right now, it's
ad the Recipe file.>
Do you have your
system set up so that the xls file is automatically>updated?>
Sergei
wrote:>
Is it possible to load the Recipe file (.xls)programmatically?>
Sergei
(3,773 Views)
Nice idea, thank you.
Sergei
> system.
> Khalid
> >>>Andrew,>
> reload Recipe>
a
> etc.>
Sergei>
Andrew Monat w
rote:>
Sergei ->
Right now, it's
> not possible to programmatically reload the Recipe file.>
Do you have your
Sergei
> wrote:>
Sergei
(3,773 Views)
