Lookout
Remote Pot resets to original value - Lookout 6.0
We have three HP computers tied to one system, each running Lookout 6.0.  All computers are running the same Lookout application.  The operator tries to enter a value using the remote pot, but the pot value keeps jumping back to the previous value.  I have updated the lookout.ini file with the SnapDelay set to 65 on all three computers.  I updated the lookout ini files on Wednesday and everything worked fine for about 1 1/2 days and then the problem started again.
All computers are connected to PLC via Ethernet.  One computer is connected to a CPU, while the other two are connected to the RBCs.  We are using Siemens hardware and Tiway database.
If I disconnect two of the computers, everything works fine - which is expected.
Could this be a bug in Lookout 6.0?  Similar applications, using Lookout 5.1, at different locations, work fine.
(3,569 Views)
Install Lookout 6.0.2, and lo602_updates.zip in the download page.  This may solve your problem.
Ryan Shi
(3,554 Views)
